how often?
do you guys have to adjust your chains? it seems i have to adjust mine every 2 weeks to keep it in the 1 to 1 3/8 spec honda calls for. i'm thinkin it would be okay to go up to 2 inches of slack between adjustments. what do you guys think? thanks
You shouldn't have to adjust your chain every two weeks. Usually about 2-3k miles or so. Are you sure the axle is torqued to 69 ft lbs? Also, don't let it get to 2" because it'll slap around way too much.
yup, its 69ft/lbs for shure. i already replaced my axle, washer, and nut do to honda's saki-suckin robots tightening the axle nut at the factory to God knows what and fookin the threads like a drunk geisha girl.
