How fast can you go?
Old 04-01-2006, 02:53 AM
Default RE: How fast can you go?
Yep looks like it
If you were going that fast....would you want your handlebars shaking???
Just helped to keep the bike straight/stable when going that fast
  #52
Old 04-02-2006, 12:41 AM
ORIGINAL: HonG
ORIGINAL: chaos321
The most I've seen on my 2001 is 173. No matter how many times I try, I can't seem to get past that. Run out of road, traffic, any thing to slow me down.
wow.. 173... is that possible?? wat mods do u have?
I have a 99F4 with a complete F4i upgrade. Erion full exhaust, K&N filter, PCIIIr, custom map, 520 chain and sprocket, cams degreed. I indicated 173mph all of the times I ran it up. Now they say the speedo's are off by usually 10%, if you figure it in, it is 17mph off which would put actual speed at 156mph. Which is right where it should be with optimum conditions. Yes, high speed passes are dangerous, but go preach to someone else. I don't ride all these bikes according to what some moron thinks is safe. I ride it on the edge, if you don't like the edge, don't go there! By the way. I'm not bitching at the guy I am quoting, I was using his quote to let him know what engine mods I have.
  #53
Old 04-02-2006, 12:44 AM
ORIGINAL: az cbr 1
So on that clip of that guy topping out his F4i, was he tightening his steering damper before taking off? If so, for top end speed, is that a big safety precaution?
You can get some serious high speed wobble when going that fast. A little rise in the road will really hoist the front end, coming back down at speeds like that will get your front shaking something fierce.
  #54
Old 04-02-2006, 01:35 AM
Fox's Avatar
Fox
Fox is offline
154 indicated.
I was going down a slight incline, which certainly helped.
This of course, was in a closed-course, sanctioned event... ;-)
  #55
Old 04-02-2006, 05:47 PM
So let me get this straight, they say your accuracy is off 10% of your actual speed. How do you tune that?
  #56
Old 04-07-2006, 03:29 PM
ORIGINAL: smokeyF4i
there's an electronic device called "speedo healer". your speed is determined via the vss (vehicle speed sensor) which ends up being represented as a voltage. the speedo healer is basically an adjustable resistor (rheostat). it has some extra circuitry in the case where it would have to actually INCREASE the voltage, so it requires power, and is more complicated than just a resistor. but if yours reads really high, finding the right resistance needed is a cheap alternative.
mine is off the same as my honda car, 4% high. i used gps and various police radar signs (you know the ones - "your speed is ____"). very helpful when calibrating the speedo. i can deal with it, and sometimes is helpful to believe you're going a little faster than you are. i just do the math - indicated 52 = 50, 73 = 70, etc. so indicated 156 = 150 in my case, although i've never been that fast.
  #57
Old 04-17-2006, 03:46 PM
I'm new on this FORUM but not new on a BIKE...the fastest I ever went was 145mph...last night did 142 easy...I don't know if the 06rr is faster than the rest but the bike felt like it could muster up to 165-172...the world looks different at 145mph...everything looks narrow...lol
  #58
Old 04-18-2006, 12:51 AM
kash's Avatar
I'm pretty sure I went 135MPH today. After 130MPH there is no way I'm looking at anything other than the road. I can't even see the speedo at this speed! Crazy!
  #59
Old 04-18-2006, 01:16 AM
in my brief moment of fame i had my bike up to 169 @13,500 RPM then followed shortly by a felony arrest....not fun
Metilj
07-08-2009 05:44 AM
cwmc29
06-28-2009 10:24 PM
Juliet
06-09-2009 09:31 PM
jasonty
07-09-2007 10:21 PM
rrasco
11-02-2006 02:10 AM
Quick Reply: How fast can you go?
