how do you higher front forks?
Old May 3, 2010 | 05:43 AM
jae_nyce's Avatar
Default how do you higher front forks?
when i bought my bike the previous owner lowered the front forks about 6 inches and i want to higher it back to stock height.. thanx for the help
Old May 3, 2010 | 10:12 AM
DBEAU's Avatar
You have to suspend the bike from the frame some how. Ideally you would want a triple tree stand; it lifts the bike with a pin inserted where the steering stem mounts to the frame. When I had to raise mine I used a come-a-long and a chain wrapped around the top triple; not ideal but it worked. Then you have to loosen the bolts that hold the forks to the triple tree. Then the fork tubes should move freely within the clamps.
Good luck.
Old May 3, 2010 | 11:55 AM
vangill's Avatar
July 2010 ROTM
exactly what he said^
Old May 3, 2010 | 01:05 PM
dave ls1's Avatar
You can also use jackstands under the motor-to-frame bolts to hold it up while you mess with the front end. I put rags over the tops of the stands and used ratchet straps from stands to frame and to keep the stands together so they wouldn't spread. It was fine like that for over a week.
Old May 3, 2010 | 01:25 PM
vangill's Avatar
July 2010 ROTM
i wanna see pics of it lowered 6 inches
Old May 3, 2010 | 04:29 PM
Kuroshio's Avatar
I'd check the rear for lowering too.
I can't see someone dropping the front and not the rear.
Old May 3, 2010 | 04:40 PM
jae_nyce's Avatar
nope rear is stock height.. i said the same thing myaelf
Old May 3, 2010 | 04:43 PM
Kuroshio's Avatar
What? Was this some guy's stoppie practice bike?
Old May 3, 2010 | 04:45 PM
jae_nyce's Avatar
lol na
TMAX
CBR1000F Wanted / Swap
Nov 18, 2009 12:41 PM
mif_slim
Jun 20, 2008 02:15 PM
abreu3r
Apr 24, 2006 05:55 PM
