How to clean chain lube from plastic?
Old Jul 13, 2007 | 08:19 PM
Daffy472's Avatar
Default How to clean chain lube from plastic?
Well,lubed the chain too much I guess, and now around kick standsome nasty mess [8D]Any suggestions on how to clean it without damaging the fairings?
Old Jul 13, 2007 | 09:04 PM
lild14's Avatar
Default RE: How to clean chain lube from plastic?
well.....i use bug remover made by Harley Davidson....cause thats what we have around my dads shop. i use it to remove anything on the bike, bugs, grease dirt whatever. works very well.
Old Jul 13, 2007 | 09:11 PM
01600F4i's Avatar
dont use chain lube. my buddy bought honda chain lube once and it was slingin everywhere. I use chain wax. it never splatters.
he uses chain wax now too.
Old Jul 13, 2007 | 10:40 PM
mikeys06cbr600rr's Avatar
wow i use PJ1Blue its made here in AZ its awesome you put on to revolutions worth and wipe the rest off unlike the others were is says to put a moderate amount which means like half the can and to remove excess i use spray polsih which takes off everything and anything its good stuff i get mine from cyclegear in the brand i use is motoboss which is there brand i dont like chain wax dirt/grime tends to stick to it more than the lube in my experience
Old Jul 13, 2007 | 10:52 PM
shraz's Avatar
I use Maxima Chain Wax and always get some lube on my bottom part fairings just around the kickstand. When I clean it, I use WD-40.
Old Jul 14, 2007 | 01:30 AM
VoodooStar's Avatar
ORIGINAL: shraz
+1 on WD-40
Old Jul 14, 2007 | 03:15 AM
Built B16a's Avatar
+2 on WD40.. its cuts throught that grease like butter.
Old Jul 14, 2007 | 04:22 PM
try to keep away from chemicals that eat paint/plastics i dont know how harsh wd-40 on paint is but for sure keep away from brake cleaner!thats why i use the polsih it cuts thru grease like butter and puts a nice protective coat as well
Old Jul 14, 2007 | 04:49 PM
golfbum69's Avatar
+3 on WD-40 ...............The best thing to cut through the chain lube.
Old Jul 14, 2007 | 05:25 PM
urandaman's Avatar
on the subject of chains.. when you clean the chain.. and use kerosene.. are yal using K-1 stuff ? i hope so cuz thats what i just used ha.
