hotbodies led turn signals
Old Aug 25, 2006 | 09:51 PM
snowboarding82's Avatar
Default hotbodies led turn signals
They came today!!! Ok so I'm going to go install them now I'll post pictures when I'm done. =) Now I just need a nice undertail!
Mike
Old Aug 25, 2006 | 09:57 PM
Default RE: hotbodies led turn signals
Ok I'm stuck already. How do you take off the stock turn signals? I don't want to just start unscrewing things and then not be able to put them back. lol Do I have to take the front fairing off? I have an 06 F4i.
Mike
Old Aug 25, 2006 | 10:03 PM
Ok I did a search and I guess I do have to take off the front fairing and some intake thing. Man I'm gonna mess up my bike I can tell already. People were also saying stuff about resistors and crap I hope I dont need any because I don't know jack crap about electronics I work at a damn credit union! lol
Mike
Old Aug 26, 2006 | 02:36 AM
And disregard this post I'm posting in the general tech. Hopefully making a write up too.
Old Aug 26, 2006 | 11:58 AM
Blackdog F4i's Avatar
Just go slow. Everything in the front comes apart in a logical manner.
As far as resistors, you don't need them. You will get a fast blink with LEDs and no resistors, but it's no big deal. I have had mine fast blink for a year now.
If it really bugs you, the best way to fix it is to replace the stock flasher with a no-load flasher relay. This eliminates the heat issue from the resistors.
Old Aug 26, 2006 | 04:21 PM
bruha's Avatar
You should also connect them with diodes.
For the resistors, I bought a 5-pack of 330ohm and 470ohm 1/2 watt resistors from radio shack. Connected 2 330's and 2 470's in parallel for each side; totals around 100 ohm, sinks <2W. I also used 1A diodes instead of 3A since I'm only drawing ~100mA. I think it still flashes fast, however I don't know how fast they flash without any load. $2 for the R's, $3 for the diodes = $5 total.
I think to get a slower flash you need 4-8ohms whichs draws a ton of power (20-40W) and gets hot, so you could check out the relay solution albeit it may be more expensive.
Andrew Vigotsky
Jun 12, 2013 06:21 AM
ryman546
Jun 27, 2007 07:30 PM
CBRgator
Jan 20, 2007 06:10 PM
snowboarding82
Aug 28, 2006 05:42 PM
El Magico
Oct 31, 2005 03:20 PM
