Horn fuse location??
Old Mar 8, 2006 | 09:00 PM
p01ishedF4i's Avatar
Default Horn fuse location??
Hello,
I have a 2001 F4i with a non-operational Horn. Is there a fuse located anywhere that might be blown? I also have not been able to check the connections to the horn yet. Anyone have an idea?? My service manual does not list any information about a Horn Fuse.
Thanks in advance!!
~Paul
Old Mar 9, 2006 | 03:47 AM
Icefox's Avatar
Default RE: Horn fuse location??
Try unhooking your battery and hooking the horn directly up to the battery itself, if the horn doesn't sound then the problem is somewhere else. My manual doesn't have the wiring diagram for some reason so I can't look for the fuses on there. You can pull off your front seat and check the fuses at the fuse block there to see if any of them are blown also.
Old Mar 9, 2006 | 01:16 PM
Fixed!! Checked the fuse, it was fine..
Then actually looked at the horn.. A disconnected terminal.. Plugged it in, and HONK!!
Old Mar 9, 2006 | 09:37 PM
DThompson's Avatar
My buddy bought his bike with the horn not working and that same piece was disconnected also. What a coincadence.
Old Mar 10, 2006 | 06:29 AM
shraz's Avatar
some dont want the horn sound
ObsidianOne
Feb 9, 2014 04:37 PM
fitbmx180
Jul 11, 2012 11:02 PM
F2Supersport
Mar 15, 2011 04:44 AM
taymax14
Jul 3, 2007 12:12 PM
subestol12
Mar 5, 2007 12:56 AM
