Honda cbr600f4i 2002 tach
Old Jun 5, 2022 | 03:12 AM
Dazjenks's Avatar
Default Honda cbr600f4i 2002 tach
Just had a healtech gear indicator fitted but now my tachometer does not work when you turn key the tachometer does the clean sweep but when bike is started the tachometer does not work I am trying to find who is at fault the company which fitted it or the healtech gear indicator is faulty and caused damage
Old Jun 6, 2022 | 08:45 AM
Scott91370's Avatar
Have them remove it - put it back to stock - and see if the tach works. If so then it's probably the indicator.
Old Jun 6, 2022 | 09:01 AM
Dazjenks's Avatar
put it back to normal and still the same
Old Sep 26, 2022 | 02:45 PM
Dazjenks's Avatar
put it back to normal still doesn't work
Old Oct 2, 2022 | 10:56 AM
Mpp's Avatar
Mpp
Check the rev counter wire where it goes into the ECU. If the rev counter wire was pulled when the gear indicator wire was being attached to it, it might have pulled the wire in the ECU connector block. This could cause a bad connection.
Old Oct 2, 2022 | 02:11 PM
Dazjenks's Avatar
ok will have a look
Old Oct 2, 2022 | 02:12 PM
Dazjenks's Avatar
ok will have a look
thanks
Old Oct 2, 2022 | 02:22 PM
dannoxyz's Avatar
Did you do this or company that did install?
Cip2076
Sep 9, 2019 07:52 PM
Cip2076
Sep 9, 2019 06:07 PM
