HID Help
Old Dec 7, 2009 | 01:35 AM
caddylicious's Avatar
Default HID Help
Hey guys i just purchased from SharpHID.com the dual bulb/ballast 35w from them, will this fit my cbr f4i? or do i need the single one? thanks!
Old Dec 7, 2009 | 08:15 AM
redzintimidator's Avatar
that will work....as long as its the right bulb type(both our bulbs are the same type)
Old Dec 7, 2009 | 04:37 PM
jondevos's Avatar
H7 type bulb for our bikes
Old Dec 7, 2009 | 07:34 PM
Okay thanks! i've seen a lot of f4i's with only 1 hid light and couldn't find much with two.
Old Dec 7, 2009 | 07:41 PM
Elfling's Avatar
Ladies Lounge Moderator
Good post by jondevos on doing two HIDs:
https://cbrforum.com/forum/showpost....6&postcount=17
Old Dec 8, 2009 | 06:33 AM
thanks man! appreciate that.
Old Dec 8, 2009 | 06:36 AM
has anyone ever tried installing the HIDs without getting a relay? just running them straight? or do we need a relay?
Old Dec 8, 2009 | 09:47 AM
Zero1080's Avatar
^You don't NEED one, but the draw from the battery might not be sufficient enough. Harness is cheap and smart. Like a condom.
Old Dec 8, 2009 | 01:58 PM
Ah i see, thanks again zero! Where can i get the harness from is the one from ddmtuning.com good? do i need two since i got the dual set up?
Old Dec 8, 2009 | 03:32 PM
jondevos's Avatar
You will need 2 relay harnesses. One for each kit. Im sure the ones from DDM are fine. I am ordering 3 this week sometime.
