HID Help
Hey guys i just purchased from SharpHID.com the dual bulb/ballast 35w from them, will this fit my cbr f4i? or do i need the single one? thanks!
that will work....as long as its the right bulb type(both our bulbs are the same type)
H7 type bulb for our bikes
Okay thanks! i've seen a lot of f4i's with only 1 hid light and couldn't find much with two.
thanks man! appreciate that.
has anyone ever tried installing the HIDs without getting a relay? just running them straight? or do we need a relay?
^You don't NEED one, but the draw from the battery might not be sufficient enough. Harness is cheap and smart. Like a condom.
Ah i see, thanks again zero! Where can i get the harness from is the one from ddmtuning.com good? do i need two since i got the dual set up?
You will need 2 relay harnesses. One for each kit. Im sure the ones from DDM are fine. I am ordering 3 this week sometime.
