Hi-beam inop along with indicator, main beam working ok?
Hi all,
Tried searching all over but can't seem to find the right answer.
Essentially my hi-beam is not working when I flick the switch. Headlight main beam works fine however when I flick to hi-beam the main beam stops working until I flick it back. I've replaced the bulb & the relay to no avail. I've stripped the switch down, checked all solder/wiring connections and they seem ok. Checked the starter switch soldering/wires & funnily enough in due course of me trying to figure it out the headlight solder snapped so I've fixed that but still no hi-beam!
Anyone had this before or can advise? I'm quite good with fixing things but this is frustrating and I'm not so savvy on wiring but this is my only thought..
