HELP... Trying to install lowering link
Old 07-17-2010, 04:32 PM
drewbagel423's Avatar
Default HELP... Trying to install lowering link
I have the bike jacked up right now, trying to install a new lowering link. Has anyone tried this on their f4i? I can't get the upper bolt out of the link because the swingarm is in the way. Anybody know what to do?
Old 07-17-2010, 06:08 PM
bluedevil3758's Avatar
when i took out my lowering link i used a jack with a piece of wood to move the jack up an down till i could get to the bolt, hope this helps
Old 07-17-2010, 06:11 PM
Ok now I'm stuck with the bottom half. I can't get the bearing out of the hole to be able to pull the stock link out of its place.
Old 07-18-2010, 08:34 AM
i meant to say move the swingarm up an and down and if i remember correctly the bearings stayed in, but it was a while ago, just whack it to get it out if you need to
Old 07-19-2010, 04:31 PM
Ok what I had to do was loosen the bolts on the two pieces that the link sits in between, then it fell out. Definitely don't wanna just whack that thing because then you'll mess up the bearing as it protrudes from both sides of the link.
Those bearings then needed to be reused on the longer link.
5t341th
06-28-2013 07:44 AM
jtboyd91
07-23-2010 08:24 PM
Witchking
03-15-2007 01:46 PM
delta
04-04-2006 03:27 PM
Quick Reply: HELP... Trying to install lowering link
