Help!!! Trying to instal T-motorsports integrated tail light
Old Feb 26, 2012 | 01:32 PM
hondacbrgirl89's Avatar
Default Help!!! Trying to instal T-motorsports integrated tail light
I need help installing a integrated tail light.....
What hooks up to what?
Old Feb 26, 2012 | 04:31 PM
zimdbw74's Avatar
3 Wire Group
Black = Ground
Red = Brake Light
Yellow = Running Light
2 Wire Group
Blue = Turn Signal
Yellow= Turn Signal
The Red will go to constant power so when ever the key is turned it should be getting power
The Yellow will go to the wire that only gets power when you press the brakes
Black is a constant ground to the battery or to the frame
With the Turn signal lights you are going to need to see what wires on your bike go to what side, either right or left and then see what wire on the light coincides with that side.
Easiest way to do all this is get yourself a circuit tester like this it makes testing the wires so much easier. Also use proper connectors and shrink wrap for a professional install.
Old Feb 26, 2012 | 04:37 PM
voxtrox's Avatar
the plug you ripped apart would have mounted into the stock lights socket (like a bulb).
Old Feb 27, 2012 | 10:23 AM
City Bike Racing's Avatar
June 2012 Ride of the Month
I did the same thing when I installed mine. After i realized that I was a moron I put it back together and it installed easy as pie.
Old Feb 27, 2012 | 04:38 PM
I didn't take it off that was a picture off their website! Thanks it's installed now!
willduce
Aug 18, 2012 08:05 AM
FightasCBR600
May 26, 2011 09:09 PM
jordan f4i
Mar 1, 2011 04:18 PM
irocthestreet
May 31, 2009 11:45 AM
vipercwf
Mar 31, 2006 10:14 PM
