Help Thread: Keyword Headlight High Low Beam Problem Don't Doesn't Work
Old May 12, 2007 | 02:37 AM
motonewbie's Avatar
Default Help Thread: Keyword Headlight High Low Beam Problem Don't Doesn't Work
No need to reply to this thread this is just a thread for people to see when they search for this because it seems like a common problem in the first model F4i.
Today my headlights failed and I searched this forum and other forums and I found out the problem. People were saying there was a wire loose within the starter assembly (lights go out when you press starter). Well anyways I went into my garage and it turns out my start button wasn't fully depressed causing the headlights to stay off, I had to pull it out about half a millimeter. So if you have this problem where both of your lights dont work or go on and off, the easiest solution before anything is gently try to pull your start button outward. Yes I know I've been a great help I take paypal donations [8D]
Old Sep 9, 2008 | 09:33 PM
ylsf04's Avatar
Default RE: Help Thread: Keyword Headlight High Low Beam Problem Don't Doesn't Work
Any suggestions on a cbr900rr? only the hi beam comes on. I replaced the bulbs and the low beam came on but then went out again??? I checked the volts on both hi and low beams, checked both start button and light switch and nothin seems odd. Please help
cbr_rob
Apr 1, 2013 10:03 AM
Santos4288
Dec 21, 2011 07:24 AM
zjwilliams
Jul 18, 2010 01:20 AM
Oldest Sage
The Hurricane Saloon
Jun 19, 2009 09:18 AM
cut_cutta
Feb 18, 2009 02:49 PM
