help rewiring tip over sensor
I just bought an 05 f4i out of an auction and the front end is gone. the upper and headlight have been removed and i only have a coupld of peices. all the harnesses are intact. the bike will crank but not start. i dont think i have the tip over sensor so...
please tell me what wires to bypass out of what harness. i would really appreciate detail. thanks alot.
by the way its a stunt bike so i dont care about the tip over sensor.
RE: help rewiring tip over sensor
there are two gray harnesses the lead to the front of the bike. you are looking for one on the clutch side the plug has a green wire on one side and a red/white on the other. they are the last pins on each side. tie those two together. you are ready to go.
let me know if that helped
