help replacing levers
Old Mar 2, 2007 | 04:05 PM
Slipspace's Avatar
Default help replacing levers
Believe it or not I found nothing in a search so here is my question:how do you replace the clutch and front brake levers? I already swapped the clutch lever out with an aftermarket one and now it feels very loose, I think the brake lever is just going to cause more frustration, if anyone has good knowledge on this please help me out.
Old Mar 2, 2007 | 04:42 PM
Tahoe SC's Avatar
Default RE: help replacing levers
just a matter of removing the bolt and replacing the lever in.
you'll need to adjust your clutch cable with the round wheel on the clutch handle to get it right. remember you can also adjust the other end of the cable on the right side of the bike.
Old Mar 2, 2007 | 04:52 PM
cbr_newbie's Avatar
some aftermaket levers fit kinda funny i had to take a hack saw to one to make it fit/work right
Old Apr 18, 2008 | 09:05 AM
drewbagel423's Avatar
ORIGINAL: Tahoe SC
wow i know this thread is over a year old but rather than starting a new one i figured i'd try to revive this one...
its just a simple unbolt-bolt? i dont know eactly how the levers work so im just curious if anything needs to be done with the lines
thanks!
Old Apr 18, 2008 | 09:21 AM
Jump1979man's Avatar
yes, it is as unscrewing the nut, take out the bolt, replace lever....this is on brake side.
Clutch side is the same but you have to adjust the cable to be loose then remove the cable and install the same way just reversed.
Very easy to do.
Old Apr 18, 2008 | 01:50 PM
thanks for the response... someone mentioned greasing the pivot bolt and making sure not to over-tighten it, would you agree?
Old Apr 18, 2008 | 01:57 PM
ORIGINAL: drewbagel423
Yes I would agree. The instructions that come with the Pazzo Levers also state this.
Old Apr 18, 2008 | 05:31 PM
Aken's Avatar
July 2008 ROTM
Remember that you want a little jiggle in your clutch lever - you should be able to move it about 1/8" - 1/4" back and forth before the clutch cable starts to be pulled. This will keep you from overtightening the cable to the point where your clutch is never being fully disengaged, thus severely shortening its lifespan.
Old Mar 16, 2009 | 10:16 PM
Omarlito21's Avatar
I bought some levers and was very iffy about putting them on of fear i might mess up the clutch or brake but after i finally did it i found out it was very easy took 15 minutes and u cant possibly mess nothing up so go 4 it
Frank Lee
Mar 16, 2011 08:38 AM
flyboy1011
Mar 9, 2009 12:03 PM
Juggalo_X
Jul 18, 2008 02:05 AM
crunkchris
Jun 22, 2007 07:00 PM
whizzif
Oct 27, 2005 04:58 PM
