help please
i was riding the other day and my bike just cut out now it wont start when i got it home the spark plugs were not getting any voltage for some reason idk what the problem is but the plugs arnt bad either and no wires are shorted out
Take the spark plugs out of the head and check them. Ignition needs three things - air, fuel, spark. If the pump is priming, that means you have fuel. We don't know if you're NOT getting any air - but you probably are because you only noticed the plugs weren't getting any power, so that's probably the faulty area. Check for discoloration at the tip and see if the give off spark. If all four are not giving off spark, then it's not your plugs. :0p
