Help needed with subrframe
Old 05-30-2008, 02:13 PM
dabaka's Avatar
Default Help needed with subrframe
Hello folks,im looking for some help about the subframe of my f4i.I crashed it few days ago and now after reviewing the damages i got stuck on the subframe.
It has been twisted and moved to the right side of the bike if you are in riding position(i crashed it on left side)
So my secret question is,does anyone know if the subframe is supposed to be in the center of the tire(like equal gap between the subframe and tire) or just a little bit on one of the sides
Here check out the pictures so you can get and idea of what im talking about
Thanks in advance
P.S. Looking for a headlight if anyone has something in mind
Old 05-30-2008, 07:05 PM
MC_spirited's Avatar
Default RE: Help needed with subrframe
It does look odd because of it being off center. From the picture it looks like both rails are paralell to the tire. Does it look twisted? Is there the same distance between the front and rear of the tire and the subframe on each side?
Old 05-30-2008, 08:50 PM
Todd84's Avatar
Mine is twisted the other way so I had to space the exhaust as it was hitting the swing arm. I just ride it Haven't got the ambition to fix it yet. If it is tweaked run your fingers along it and feel for a spot that is bent. I can find it on mine.
Old 05-31-2008, 12:15 AM
dabaka's Avatar
Yup it was twisted in the right corner,which was higher than the left one but we got that fixed. And no they are not paralel with the tire on both sides this is what we try to figure out if the subrame should be centered or a kinda on one of the sides so when you look it from behind the tail looks ok
Olilocost
05-12-2013 04:44 PM
Fubadu_the_Mighty
F3 Wanted
06-22-2010 11:38 AM
Tazkb
The Hurricane Saloon
04-24-2010 06:39 AM
barryem
05-08-2007 01:55 AM
stilin
09-20-2005 10:19 PM
Quick Reply: Help needed with subrframe
