Help me identify which fairings I have
I need to either replace my right fairing or fix it. Got a little damage recently. My fairings are not the typical ones that everybody has. I guess the previous owner bought some cheap version or something. The only part of the fairings that can easily let you know they are not stock is the connection between the upper fairing and the side fairing. Instead of the common 3 bolts that connect everything, my fairings only have one plastic fairing clip/bolt/screw thing! check out the picture below.
You either have aftermarket fairings or you have OEM fairings that were repaired by someone who decided to cover up the holes for a cleaner look.
Either way, I'm guessing you can put an OEM or aftermarket fairing on, and just attach the upper hole instead of all three, so long as it's in the original location (which it appears to be).
