Helmet Lock
Old Oct 13, 2005 | 01:58 PM
tystik's Avatar
Default Helmet Lock
The lock mechanism under my rear seat likes to break at very inconveniant times, like when my helmet is locked in it and i'm not at home. Today i ended up just riding home with no helmet. I've had to pull the front seat off and fix the lock a number of times, but it always seems to get F'd up again. Any suggestions? Has anybody else had this problem. I have an '03 F4i
Old Oct 13, 2005 | 05:10 PM
regener8ed's Avatar
Default RE: Helmet Lock
when you "fix" the lock - what are you having to fix?
Old Oct 13, 2005 | 07:10 PM
tystik's Avatar
By fixing it I mean readjusting the metal thingie that attaches to the actual piece that locks. It somehow comes un-attatched and needs to be adjusted to work correctly. If you look under the rear seat you'll see what i mean.
Old Oct 13, 2005 | 11:21 PM
OutToWin PAHC's Avatar
sounds odd mine is spot welded from tha factory attached to the cross bar of the subframe, seems weird what year I have an 01
Old Oct 14, 2005 | 01:50 AM
tystik's Avatar
It's the metel thread with a tiny metal cylinder at the end. The cylinder fits into another metal piece that actually locks the seat in. That is the part that comes out
Old Oct 14, 2005 | 02:00 PM
deeksmooth's Avatar
can u point it out here? cause when u say helmet lock, i see what i have pointed out in this pic.
Old Oct 14, 2005 | 05:17 PM
regener8ed's Avatar
yeah, guys - i don't think he is referring to the helmet lock. it's the locking mechanism for the whole seat that he's referring to.
i can't say i'm aware of this as an issue -- might try something to secure the cable in the socket better -- a wire tie, jb weld, whatever works for the situation.
Old Oct 14, 2005 | 09:30 PM
yeah im with you on that one, the helmet lock doesn't "come off" Now iv had problems getting my helmet out of it cause its a tight squeeze. I would make sure I fix this right, what ever you are trying is not working if you know whats needs to be done and you cant do it take it to a mom and pop body shop im sure they can correct it either with a spot weld, or another method.
Old Oct 15, 2005 | 05:35 PM
tystik's Avatar
yea i will probably try to get it welded. Thx for the advice
Alex Poland
Oct 22, 2012 11:49 AM
JankCibberf2
Aug 23, 2011 10:03 PM
koelzer18
Mar 27, 2006 01:12 AM
