HEADLIGHT LENS
Old Apr 14, 2008 | 12:47 PM
BAGD RANGER's Avatar
Default HEADLIGHT LENS
HEY GUYS HOPE YOU CAN HELP IM NEW TO THIS FORUM AND HAVE BEEN DOING MY RESEACH AND READING --- BUT HERE IT GOES
I RECENTLY CRACKED MY HEADLIGHT LENS ON MY 2002 HONDA CBR F4I -- QUICK QUESTIONS -- CAN I JUST REPLACE THE LENS OR AM I S.O.L AND HAVE TO REPLACE THE WHOLE LIGHT -- PLEASE HELP --
AND IVE SEARCHED AND DONT KNOW OF A SITE WHERE I CAN BUY JUST THE LENS --- PLEASE HELP -- THANK YOU !!!
Old Apr 14, 2008 | 12:52 PM
ffingers's Avatar
Registered Users
Default RE: HEADLIGHT LENS
you should be able to just replace the front clear headlight "lens" (i am assuming that is what you are talking about)...only issue being is that i doubt they sell it individually.....i just checked on the online fiche and you can't get the lens separate from Honda....your best bet will be to check out ebay for some cheap headlight housings....
Old Apr 14, 2008 | 12:57 PM
THATS WHAT I WAS THINKING IT JUT SUX CUZ THE LIGHT AND EVERYTHING ELSE IS FINE - I NOW JUST HAVE A BIG *** CRACK IN THE LENS ---- THANKS FOR THE INPUT -- ANYBODY ELSE ????
Old Apr 14, 2008 | 01:05 PM
Xx New Guy xX's Avatar
2 things - 1, press caps lock, it looks like you are yelling and 2 - you will have a tough time finding just that clear plastic, i would follow ffinger's suggestion to try to find an entire housing. The problem is they actually glue the lens to the housing so it can be sold as one unit.
Old Apr 14, 2008 | 01:15 PM
caps lock --- sorry i actually get that alot when im on the computer ---- so i may to just buy a new light housing ???? --- where can i get that ?? and what doe something like that usually run ???? -- thank you guys !!!
Old Apr 14, 2008 | 01:21 PM
ffingers's Avatar
Registered Users
well, it can go either way...one is going up for $200+ and one is at $20 or so....since you just need the clear, the mounting isn't an issue so you could get a broken one so long as the lens is good...search around...
here's an ebay search...
http://search.ebay.com/search/search...=32&fsoo=2
Old Apr 14, 2008 | 01:41 PM
THANK GUYS I APPRECIATE THE HELP -- THANK YOU !!!!
Old Apr 14, 2008 | 02:17 PM
whtan20's Avatar
They are just like car headlights, so you can bake them until the sealant is hot enough that you can seperate the lens from the housing. Problem is i dont know where you would find JUST the lens. You can buy a cheap broken tabbed one off someone and just use the lens from that and put mate it onto yours. I'm in a similar situation and will probably do this.
ObsidianOne
Nov 19, 2013 08:37 PM
yumoncbr
Jan 13, 2012 02:06 PM
FlexCBRF3
May 30, 2009 01:17 AM
some guy #2
Jun 5, 2007 12:00 PM
