Headlight issue
I tried searching, but since my symptons are different, I decided to make this thread. Me and my friend changed out my front forks yesterday, so we took off the front fairing/headlight. Put everything back, tried priming the bike, but nothing happened. The fuel pump didn't even turn on, and my headlight wasn't on either. Left turn signal indicator was on, and wouldn't flash when I signaled. It just stayed on. Also, kept popping my headlight fuse under the seat. Took the front fairing off, and checked all the connections, and they seem fine. Put everything back, and continued to pop fuses. Then, both turn signal indicators stayed on, and bike would still not prime, or start.
if it wasnt doing before, then you either plugged something up wrong, or possible pulled some wires loose from the connector. almost sounds like you forgot to plug in the bank angle sensor, or it something in that circuit. the bank angle sensor will keep the bike from starting, the fuel pump wont kick on
