Having trouble removing the rear brake pedal
Hey guys I low-sided my bike the other week and am in the process of repairing the damage. One of the last things to fix is my rear brake pedal, which got bent. I got the new pedal today, and when I went out to install it, I couldn't get the old one off.
The service manual merely states to remove the joint pin, and the springs, and viola. Well I don't see any way to remove the joint pin, and I don't know if it's because something is bent or because I'm just stupid. Any help would be greatly appreciated. Here are some pics. (BTW the joint pin is that gold pin with the square end.)
lol comon guys.
take a look at the last picture you posted in the OP...
you need to pull up the pedal about 1/2 inch to allow the gold pin to drop out, but the master wont let you......
.....SO remove snap ring 1st, then remove the 2 bolts to separate the master from the rearset bracket and you can now easily pull out the gold pin.
lol comon guys.
