Has anyone done the <$10 CCT fix?
Old 06-11-2007, 07:03 PM
ampfp's Avatar
Default Has anyone done the <$10 CCT fix?
I refer to this:
https://cbrforum.com/fb.asp?m=194939
I got the bolt as in the post, but there's just no way I could find to get the original one out without removing the entire CCT!
Is there a way to do this? I don't want to mess anything up just while reducing some vibration and removing the CCT needs some tool that'll go through the hole in the frame (
Has anyone done this?
Thanks
Old 06-12-2007, 05:51 AM
axsys's Avatar
Default RE: Has anyone done the &lt;$10 CCT fix?
well i tried it on a J22 that was already making the noise and it did nothing. i would suggest buying a new oem one or an ape manual one. after all, its 40-50 bucks for a &gt;$5000 bike so i dont think thats too much of a price to pay.
________
Essential vaaapp vaporizer
Old 06-16-2007, 04:14 AM
Default RE: Has anyone done the <$10 CCT fix?
I followed these easy instructions:
http://cbrworld.net/forums/thread/85183.aspx
And did the freebie fix/mod:
http://cbrworld.net/forums/thread/261176.aspx
It worked out 100% and no more noise!
Old 01-09-2008, 12:16 AM
Try one of these, they may help, first one is my method, iv'e never had the pin problem, just weak spring problem.
https://cbrforum.com/m_460225/tm.htm
Graham
Cheers
Old 01-09-2008, 09:12 AM
Tahoe SC's Avatar
i've never had the weak spring problem, only pin problems....
muhahahhhahaha...
Old 01-09-2008, 11:02 AM
ur all gay...lol just buy a new one or get the manual cct...why tamper with something so cheap yet can cause so much damage?????
Old 01-09-2008, 05:42 PM
Tahoe SC's Avatar
well...you said it mang...we're all gay...and we have no bling to shell out like you.
Old 01-11-2008, 06:52 AM
Rumblebug77's Avatar
After replacing the OEM tensioner and getting the same results (with noise) I put on a manual tensioner. That was a year ago at 16000 miles. I now have 33000 miles and haven't had the first bit of trouble from it. Not an expensive thing to do and it seems to last a lot longer the OEM part.
I woulnd't recommend doing it yourself unless you are very comfortable with things like this. You can very easily over adjust it and eat the plastic guide up inside the case.
Old 01-11-2008, 08:42 AM
$45 is bling for you...lol...but f---kin your motor because of micky mousein the thing...thats like sayin well i got 3 qt of oil in it but i'm too cheap to buy the 4th...gay!
ORIGINAL: Tahoe SC
Old 01-11-2008, 10:00 AM
Tahoe SC's Avatar
sound's like everything is gay to you...
ain't mickey mousing if you know what you're doing...so 'straight' guys with bling should just get a new one or go APE
