Go Away Decals!
Old Oct 17, 2011 | 08:43 PM
Busted's Avatar
Default Go Away Decals!
I am looking to do some body work on my bike. One of the things I need to do is remove all my decals, including the ones on the tank. Is there a "best" way to go about this?
I have heard a rumor that I can use mayonnaise and a heat gun but I am weary about it.
Any tips?
Thanks in advance.
Old Oct 17, 2011 | 09:05 PM
revels's Avatar
Registered Users
heat definately helps, be very careful not to scratch the paint, it scratches very easily.
Old Oct 17, 2011 | 09:08 PM
74demon's Avatar
Peel them off. Then use wd40 to remove the glue residue. Dont use heat. It will melt the plastic.
Old Oct 17, 2011 | 09:18 PM
Trey929RR's Avatar
You can use a heat gun, or some heat source to assist in removing them... never heard of the mayo part... but be careful with the heat source, if too hot/too close can cause paint to bubble/stuff to melt.
GooGone is some good stuff to invest in to remove residues of most kind... GooGone works very well, little elbow grease needed.....
Old Oct 17, 2011 | 10:20 PM
WiSH2oo0's Avatar
I used a hair dryer to heat up the decals. There is a fine line between to much heat and not enough. Once you find that perfect amount you can peel a whole decal off in one piece. I found it alot easier to do w/ the help of a friend. One guy heating up the decal and the other peeling it off. To get rid of that left over glue, I used a little bit of heat plus some WD-40 on a microfiber cloth. Take your Time..
As far as the fuel tank decals go, they are clear coated onto the tank. Only way I see to get them off is good old fashion sanding.
Moses
Old Oct 17, 2011 | 10:39 PM
kilgoretrout's Avatar
Administrator - Retired
^^ exactly what wish said. I've done this a few times.
I've used a heat gun on low a couple times, but you have to be careful. Then WD40 to clean the clue off.... or "oops" or lighter fluid. lol.
Old Oct 18, 2011 | 05:23 PM
Busted's Avatar
Thanks for the info!
So it seems using careful heat is the ticket.
I have been trying to peel them off with a blade and my thumbnail. This was not working out very well. So I am going to give this a shot.
Old Oct 18, 2011 | 05:27 PM
74demon's Avatar
just be careful...
Old Oct 18, 2011 | 07:42 PM
Busted's Avatar
I will post some pictures...Hopefully it will be because of good news.
chiefF3
Feb 17, 2009 11:51 AM
tonyB11
Oct 4, 2007 06:44 AM
silvr002001
Feb 11, 2007 05:35 PM
ss954rr
Feb 11, 2007 12:17 PM
dash
Feb 10, 2007 05:18 AM
