Gear and + Chain Mod Questions?
Does the speedometer on a 02 F4i read off of the drivetrain, or the wheel. I want to switch my gear ratio to a -1/+2 from the stock ratio, Will I need to buy a speedo healer. Also I would like to convert to a 520 chain, what sort of conversion process do I need to perform?
Yes you will need a speedo healer. As far as the 520 conversion, you need to change the sprockets (both) and chain, thats it. Buy the kit. There is NO advantage to changing from 525 to 520, unless you plan on racing. The difference is the width of the chain. The 520 is slightley smaller, therefore creates less reciprocating mass. Which means it takes a little less effort (from the trans.) to rotate the rear wheel. You'll never notice the difference unless you are racing your bike. It's also not quite as strong as the 525. Thats why most larger bikes ('Busa, ZX-10 ect.) come with a 535 set up. And aluminum sprockets wear out faster than steel ones. (Obviosly cause aluminum is softer than steel)
If you want to buy the 520 kit, it comes with the both sprockets and a chain. You just select what size sprockets you want-as in teeth. although, in reality you wont feel it on the trackday. You wont notice that slight bit of difference until you are running front of the pack A class, and trying to shave off 10ths of a second every lap. but, if you want one, get it, it wont hurt anything except that it wears out quicker.
the last time I looked at speedoheales, there were only 2 types available. yellowbox and speedohealer. basically yellow box sucked, and the speedohealer was what everyone had. 2 yrs ago there was only one place in the US that even had a license to distribute them. that may have changed by now. just type in speedohealer in google and your on your way.
Ummm...it reads faster than your going. And it racks up more miles on your bike than you really have. You never really know how fast your going til you get pulled over. Spend the hundred bucks and get the speedohealer. takes about an hour to install. Money worth getting.
-1/+2 gear ratio change, along with factory ~5% error will put your speedometer at a near 15% error. At 60mph you'd only be doing 51mph. That also means you'll be putting 15% more miles on your odometer than actual.
So yeah, the $110 or so for a Speedohealer is very worth it. The only hard part about the install is getting to the plug above the transmission (just behind/under the rear shock). I had to remove the top bolts of my subframe and tilt it down in order to reach mine, but they were also underneath the coolant overflow canister. How hard it will be will depend on where yours are tucked.
Read the manual when you get it, and the above will make a lot more sense. Also read this: http://www.speedohealer.com/your_pic...i/tutorial.htm
Here is how to install it. I took my tank off and propped it up, it helped me get to the sensor. If you have someone there, it helps to have an extra set of hands there.
Someday you might sell your bike, and if it has more miles on it than are actually on it, you probably won't get as much for it.
