Gauge Cluster LED Swap COMPLETE
Old 09-25-2008, 03:20 PM
MidnightG35X's Avatar
Default Gauge Cluster LED Swap COMPLETE
So I finished up the gauge swap this past weekend and finally got around to taking pictures. Unfortunately, when the LCD was out of the bike, a certain someone at my house knocked it off the counter causing it to crack and no longer function... Luckily this was a spare gauge cluster and not the one on my bike. I switched out the LED's with ones from Digikey, along with the resistors (see https://cbrforum.com/m_647966/mpage_1/key_/tm.htm#649475)to make sure I get closer to the rated brightness. Once I get time, I'll switch out my real gauge with this same color combo. If anyone needsgauges without the LCD (control board and tach still work) let me know, I can part with this one now Here are the pictures.
Old 09-25-2008, 04:33 PM
p4eAaLcLe's Avatar
Default RE: Gauge Cluster LED Swap COMPLETE
looks good. not a big fan of the rainbow tach all that much. Maybe you should just buy spares, put l.e.d's in the them and sell them? lol
Old 09-30-2008, 02:26 PM
sluijs01's Avatar
Nicely done! You must be quite skilled at soldering and have a pretty nice iron. What values did you decide upon for your resistors? Did you take any pics while you had it taken apart?
Old 09-30-2008, 03:18 PM
Leveltwo's Avatar
sucks about the display
Old 09-30-2008, 04:52 PM
ORIGINAL: sluijs01
Thanks. I don't have any pic's from when it was apart, forgot the camera when I did it I will try to get some when I actually do the cluster that's on my bike. As for the resistors (size 2010 surface mount), here's how it broke down:
LCD Resistors:
Single Blue LED: 620 Ohm (just reused the one already on the board originally from the double LED)
Double Blue LED: 430 Ohm
Tach Resistors:
White-Blue section: 430 Ohm
Green-Yellow section: 500 Ohm
Red-Green section: 500 Ohm
Old 09-30-2008, 04:55 PM
Luck Runs Out...'s Avatar
ORIGINAL: MidnightG35X
Whu....?
Otherwise, looks good.
Old 09-30-2008, 07:07 PM
axsys's Avatar
looks great! would you be willing to sell me just the plastic housing? 2 of the mounting holes on mine have broken off :/
Old 09-30-2008, 08:01 PM
Luck Runs Out,
The LCD cracked (the speedometer part) when I had it unsoldered from the main gauge cluster. I bought a spare cluster so I could experiment with this mod first before I did it to the actual one on my bike. So right now, I have the original one on my bike and this spare one sitting on the couch
Axsys,
Shoot me an offer, we could discuss it.
Paranoia
07-30-2011 10:39 PM
jacked600
07-06-2009 09:08 PM
MidnightG35X
09-19-2008 11:31 AM
Armstrong
06-08-2006 08:31 PM
Quick Reply: Gauge Cluster LED Swap COMPLETE
