gas tank removal help
Old 03-29-2011, 01:30 AM
pocfoo's Avatar
Default gas tank removal help
ive searched and read stuff on the forum but im still confused. ok theres the little thing in the middle with wires and plugs and stuff, then theres 2 tubes. do i just clamp the 2 tubes and unscrew that middle thing with the wires and stuff? or wtf?
im suppose to be getting it painted so i gotta figure this out ha ha
Old 03-29-2011, 06:58 AM
R Dub's Avatar
October 2011 ROTM
Do you have a pic? If I remember correctly all you have to do is unplug the fuel pump harness which should be by the frame on the left side of the bike and then unscrew the main fuel line bolt which is on the right side of the bike. All those other hoses are vents and you shouldn't have to worry about it. Just remember not to lose the fuel line bolt like me and then have to buy a new one from Honda and wait even longer to put your bike back together
Old 03-29-2011, 08:34 AM
pocfoo's Avatar
well heres some pics...
these are the 2 hoses that dont seem to lead anywhere...
and this is the thing all hooked in to the bottom that i have no idea what to do with...
Old 03-29-2011, 08:46 AM
R Dub's Avatar
October 2011 ROTM
The 2 hoses that don't go any where are the vent hoses and over flow hoses. The manual says you have to remove them but I can not remember if I did or not. If you do just be sure to label them somehow so you know where the go. The other 2 are going to be your main fuel line and fuel return. You will have to disconnect those. As for all the wiring that should be pretty easy, follow where it goes and it should lead you to a 3 prong black connector on the left side of the bike like right on the frame. Disconnect that and you should be good to go.
Old 03-29-2011, 12:03 PM
pocfoo's Avatar
ok ive got everything disconnected but one thing... the tube thats held down by this gold thing
am i suppose to just unscrew the gold part to take it off? and what should i use to get it off?
Old 03-29-2011, 12:37 PM
vegas_rebel's Avatar
When I painted my tank, I removed all of the little bolts around that gold plate and just pulled the entire fuel pump out. Then you won't need to disconnect the fuel hose (or worry about your pump getting painted.)
Old 03-29-2011, 12:50 PM
pocfoo's Avatar
oops ive already startes taking that gold peice off... is that bad? like is it goin to get messed up in paint
Old 03-29-2011, 01:26 PM
R Dub's Avatar
October 2011 ROTM
As long as you don't get gas on the new paint you'll be fine.
mrbret
01-30-2009 09:53 AM
maldy21
09-05-2008 02:43 PM
ocf4
07-21-2007 06:34 PM
schultzy
06-05-2007 07:35 PM
peejay
05-13-2005 04:50 AM
Quick Reply: gas tank removal help
