Galfer line install question
Old Apr 5, 2008 | 09:25 PM
DonEverett's Avatar
Default Galfer line install question
For those of you who installed Galfer SS lines, what did you use to mount the front fender? The stock rear bolt is too long as the "T" block for the factory lines gets mounted there. Did you just go out and get another bolt or something else? Also, how do you know when your done bleeding the brakes? No air bubbles are visible from either caliper, or from the MC. Thanks guys.
Old Apr 5, 2008 | 09:54 PM
Jump1979man's Avatar
Default RE: Galfer line install question
the front fender is held on by a bolt on either side to the forks....nothing with the lines.
as far as bleeding brakes you need to bleed them until you dont have any air bubbles from the bleeder valve.
I would also suggest these...Speed Bleeders
https://www.riverwayracing.com/store...t=2&page=3
Old Apr 5, 2008 | 10:02 PM
krash's Avatar
I just installed mine this week. On the left side of the fender(if sitting on the bike) I reused the rubber mount and bracket from the OEM. just sliced the rubber grommet with a razor blade, then put the SS line back in it.
On the right side, I happened to have an aluminum sleeve that was the exact same thickness at the "t' block that came off. I also had a clamp laying around that I used to hold the line just like the other side.
I would suggest you go to the hardware store, either find the same thread bolt, only shorter, or find a spacer that is the same thickness of the block from the factory lines
Old Apr 5, 2008 | 10:04 PM
DonEverett's Avatar
Thanks Krash. I actually have a few parts I need to order anyway, so im just going to get a bolt just like the left side (its only .99 on ron ayers) and use that. I will have to fab a mount for the line though.
Old Apr 5, 2008 | 10:09 PM
krash's Avatar
go check out the hardware store, or lowes, or something. they have all kinds of brackets and fastners and such. your sure to find something with an eyelet to hold the brake line.
Old Apr 5, 2008 | 10:11 PM
You dont need to mount your lines to anything....
Old Apr 6, 2008 | 06:56 AM
simmadown's Avatar
IF the problem is bolt length, just shorten it with a grinder?
Old Apr 6, 2008 | 07:04 AM
krash's Avatar
no I guess you dont need to mount them.
OEM mounts them, so I guess it cant hurt to mount them if someone wants too.
Old Apr 6, 2008 | 08:46 AM
DonEverett's Avatar
ORIGINAL: simmadown
My first thought haha, but the bolt isn't threaded all the way up to the head. For 99 cents Ill just get another short one.
The reason I want to mount the lines is to keep them from rubbing my fender, and to make sure they stay out of the way.
07ceeberthousand
Jul 12, 2010 04:10 AM
dondi
Mar 19, 2008 10:05 PM
nfamousdevil
Aug 31, 2007 06:51 PM
JT@bikerperformance
Biker Performance
Jul 19, 2007 12:13 PM
patas75
Jul 9, 2006 01:39 AM
