front fairing help Please
Old Dec 27, 2010 | 12:37 AM
fartman's Avatar
Default front fairing help Please
I am putting on a OEM top fairing on my sons 03 F4i I got off E bay, great shape, trying to see how fairing secures it self to the fairing stay bracket. I have the lights installed in the fairing, just not sure how the lights push in to the fairing stay, as the two holes under the speedo are without rubber grommets. I understand that these are supposed to push into holes then mirrors hold rest of fairing on.
My question is, are these rubber grommets the same size as rubber grommets under speedo?? They seem to be a bit small, and sloppy fit in holes, also dosent seem like there is enough material to go into these grommets on the headlight? Are there any other fasteners on the lights as these have a hole in them?? Hope that is clear enough to understand ??
Any pics would be great ......Thank you Derek
Old Dec 27, 2010 | 09:38 AM
jeffjones's Avatar
Here is a link to the F4i Service Manual.
https://docs.google.com/leaf?id=0Bx1...thkey=CIeS7YME
In section 2 it explains removing and installing all the fairings in detail.
Hope that helps.
Old Dec 27, 2010 | 06:22 PM
fartman's Avatar
Default still have question
Hello ok thanks for the link, had it all ready, according to parts fish, the fairing stay bracket shows 3 grommets part number19051-KA3-830, there but arent those the ones for the speedo?? The holes for the "Headlight unit Bosses" in the bracket are bigger holes. I cant seem to find these on the parts breakdown to order them?? And the bosses on the headlight dont fit into these grommets I have for the speedo.
The other concern I have is the "Headlight Unit Bosses" only have less than a 1/8th of a inch to go into said bushings. Seems odd?? Thanks again for any help ....
Old Dec 27, 2010 | 06:47 PM
fartman's Avatar
Default figured it out
OK got it, the grommets they show on the fairing bracket are the ones I need, the other ones are called "rubber meter cushion" and are in the speedometer schematic. OK still not sure on the bosses fitting into grommets now though..? thanks
Old Dec 28, 2010 | 10:18 AM
skoobydoobie's Avatar
Don't worry too much about it. My headlight has those two "bosses" broke off, so the only thing holding the upper to the bike is the four bolts for the mirrors and the six on the sides that screw into the side fairings. Been riding two seasons like that w/o issue.
Old Dec 28, 2010 | 04:02 PM
Xander F4i's Avatar
i'm guessing that they are gone on mine too
Old Dec 29, 2010 | 02:27 AM
fartman's Avatar
Default Thanks
Thanks for reading, sounds good not going to loose any sleep over it then.....
Jebbin12
F4i - Wanted
Feb 27, 2011 09:15 AM
kray923
Mar 17, 2009 10:11 AM
xxenycejattxx
Aug 20, 2008 07:31 PM
