Front caliper differences
Old Jul 16, 2008 | 06:41 AM
MC_spirited's Avatar
Default Front caliper differences
I am getting a pulsing in the front brakes. Recently changed pads and SS lines. I am wondering if I could have put the calipers on the wrong sides.
Old Jul 16, 2008 | 06:55 AM
PlayfulGod's Avatar
Default RE: Front caliper differences
ORIGINAL: MC_spirited
rotor/s could be warped.
Old Jul 16, 2008 | 10:24 AM
MidnightG35X's Avatar
Could just have air in the lines too from when you switched. Try to bleed the lines. Its the simplest solution anyway. I assume they were not pulsing before you changed pads and the lines? You might have to bed the brake pads also... not sure if that's required on bikes, but it certainly is for cars.
Old Jul 16, 2008 | 10:52 AM
Tahoe SC's Avatar
could be many things...including warped rotor, sticking calipers, etc.
i'd remove the pads, extend your pistons 1 by 1 very slowly and clean all of them.
there will be gunk around them that would prevent them from extending.
then reinstall the pads and bed them just for good measure.
Old Jul 16, 2008 | 04:10 PM
I disassembled and cleaned the calipers before putting them back together and installing the new Galfer GG pads. The brakes felt a bit weird under hard braking before the pad change. After I installed the pads I was bedding the pads in and I hope I did not warp them when I did that. I am just not sure if i put the right calipers on the right sides.
Old Jul 16, 2008 | 06:20 PM
Aken's Avatar
July 2008 ROTM
I'm pretty sure due to the mounting bolt positions on the calipers, it's impossible to mount them backwards.
Old Jul 16, 2008 | 08:49 PM
damn, I was hoping it would be a stupid easy fix. I gotta get a mic and check the rotors.
Old Jul 16, 2008 | 11:07 PM
devlzluv's Avatar
like tahoe and playful said could be anythign but if it didnt do that before u changed your stuff i would really lean towards air in the lines, that does crazy ****
nrmskate
F4i - Wanted
Mar 12, 2012 09:23 AM
Cletus
Dec 5, 2007 07:29 PM
TCIRACING
Oct 8, 2007 05:50 PM
spidertron
Jun 7, 2006 04:43 AM
