Front brakes
Old Feb 13, 2012 | 08:33 AM
andy040715's Avatar
Default Front brakes
Have had this problem for a few months now. Recently when I brake with my front brakes, the brake lever goes all the way to the bar..Ill drive another mile to another stop light, it will take just a flick of the lever to slow the bike down. I can pump the front brake lever and make it so it takes just a flicker every time but it will slowly decrease and eventually it will take pulling it to the bar once again.
I have bled my brakes over and over...nothing fixes the problem.
Advice?
Old Feb 13, 2012 | 06:28 PM
MadHattr059's Avatar
If you haven't changed the fluid in a while, it could be moisture in the lines.
Even though you've tried bleeding them, you might try a complete flush and
re-fill.
It's also possible that you've developed an air leak. You can try to GENTLY
give the banjo-bolts an extra bit of torque. It's also possible to get leaks around
the bleeder-valves, as well. If you have a friend that can put their finger on the dyke.
You can pull the valves and wrap them with teflon tape and then try re-bleeding, again.
Best advice, though, DO NOT continue to ride the bike untill you get this figured out.
Sudden stops are part of the survival game, don't pull a 'Darwin'.
There are several good picture walk-throughs on complete over-hauls. If you think
you're up to it, that would be your best course. It probably could use the attention,
anyway.
Hope this helps, ern
Old Feb 13, 2012 | 06:50 PM
74demon's Avatar
sounds to me like the brake master is going out, assuming there is no leak or air in the system.
Old Feb 13, 2012 | 08:14 PM
Kevwa451's Avatar
Mine started to do this as well. I re-bled the brakes in a hurry one day and I think I re-introduced air into the system. The other day I flushed them again and took my time. The brakes used to go flat like that while sitting in the garage so I ruled out warped rotors. I just went out and checked the pressure again as the bike has been sitting for a week without me touching it and they still felt pressurized so I'm hoping I fixed it. I've already dumped about 1200 into it this winter and would like to cap my spending there. keep us updated if you find a solution.
Old Feb 14, 2012 | 12:04 AM
boredandstroked's Avatar
This just screams bad master cylinder.
Old Feb 14, 2012 | 12:16 AM
Acespad3's Avatar
+1 on the bad master cylinder. inability to hold the hydraulic pressure is bad juju
Old Feb 14, 2012 | 10:08 PM
WiSH2oo0's Avatar
Also inspect your brake pads while your at it. They may need to be replaced or even have a glaze on them increasing your braking distance.
Moses
kdbolt70
Jul 3, 2012 12:55 AM
AlexF4i227
Mar 15, 2011 09:05 PM
KenG
Aug 31, 2010 05:20 PM
95HondaCBRF3
Sep 4, 2007 04:10 PM
brian97
May 8, 2006 10:45 AM
