freakin weatherman and mud
Old Jun 7, 2007 | 12:35 PM
Tahoe SC's Avatar
Default RE: freakin weatherman and mud
yes but you shouldn't.
why don't you just spray her down when you get home from whatever it is that you do during the day?
it takes like10 minutes to wash off the dirt, etc...
spray the ****....then quickly scrub, then spray the **** again...then dry.
you don't have 10 min for your bike?
Old Jun 7, 2007 | 01:07 PM
ninetyfivehp's Avatar
because by the time i get home from work[:@]i can't see chit. i just have time too stop at the car wash and rinse her if i'm gonna make my ride saturday morning. i'm not gonna use high pressure so its really no different than spraying the bike down at home. just gonna hit her with some spot free rinse. i'm just worried about rinsing off a warm bike?[&:]
Old Jun 7, 2007 | 02:04 PM
Tahoe SC's Avatar
yea...i'm worried for YOU about hitting the block, especially around the header/radiator area with water.
don't worry about not seeing chit...just get the muck off for now and do a crappy job wash until you have time for a good one!
kinda like a snicker bar before dinner!
Old Jun 7, 2007 | 03:31 PM
allright, i'll hose her off in the dark then. is there any spray on/rinse off product that i can spray the entire bike down with that will get rid of most of the muck and not harm anything on the bike? just something to make her look respectable untill i can give her a good bath next friday. thanks
Old Jun 7, 2007 | 04:01 PM
Tahoe SC's Avatar
you will be fine...i rode my f4i through the hardest rain ever when socal was hit by the pineapple express.
as for spray to get off the muck...simple green usually does it for me...then again i've washed my bike 2x since i got it! hahahahah...
Old Jun 7, 2007 | 06:03 PM
doesn'tsimple green etch aluminum? do you dilute it or do they make a car/bike formulaproduct now?[&:]
Old Jun 7, 2007 | 08:03 PM
so i should be allright if i just hose it down, spray on some simple green (let sit for 5 minutes), then rinse good, wipe dry, and lube the chain. then i'm good to roll
Old Jun 7, 2007 | 08:23 PM
Tahoe SC's Avatar
i don't know about simple green and aluminum...
like i said when i used to wash my bike i just sud it up and then use pledge to wax it...LOL...
i'm not too much into the shine in case you can't tell.
i know that spraying the bike will be fine though. forget washing, just spray her down to get the dirt off!
Old Jun 7, 2007 | 08:41 PM
no simple green then. i'll take 10 minutes and just hose her off and go ride[8D]
Old Jun 7, 2007 | 08:51 PM
Tahoe SC's Avatar
omgosh2pgsonbikewash!!!!!!!!!!!!!!!
but you're right about simple green and aluminum partly:
Aluminum - Is it safe to use Simple Green on aluminum?
Simple Green products have been successfully and safely used on aircraft, automotive, industrial and consumer aluminum items for over 20 years. However, caution and common sense must be used: Aluminum is a soft metal that easily corrodes with unprotected exposure to water. The aqueous-base and alkalinity of Simple Green or Crystal Simple Green can accelerate the corrosion process. Therefore, contact times of All-Purpose Simple Green and Crystal Simple Green with unprotected or unpainted aluminum surfaces should be kept as brief as the job will allow - never for more than 10 minutes. Large cleaning jobs should be conducted in smaller-area stages to achieve lower contact time. Rinsing after cleaning should always be extremely thorough - paying special attention to flush out cracks and crevices to remove all Simple Green/Crystal Simple Green residues. Unfinished, uncoated or unpainted aluminum cleaned with Simple Green products should receive some sort of protectant after cleaning to prevent oxidation.
