Freak Problem on my 02 F4i
RE: Freak Problem on my 02 F4i
Took the bike apart this weekend. Couldn't find the issue.
Bike: 02' F4i 6546 Miles - First 3500 miles were put on by first owner in 4 years. Bike was garaged. Put the other 3000 miles myself (bike not garaged)
Issue: In the past month the following issue started. Would come and go, but now it always a problem. Bike turns on but has booged down power at any RPM. Specially low rpm. Both in high or low engine temps. Power at a give rpm varies slightly. I don't know why. But whatever is causing cylinders 2,3 (Middle ones) to run rich all the time is eventually messing with the sparkplugs. Causing misfires. When the bike is running it smells gas. Oil in the bike smells like gas.
Things I tried:
Week ago: Replaced Sparkplugs. Middle ones where black.
4 Days ago: Techron Fuel Injector cleaner - did nothing
1 Day ago: Checked new spark plugs. 2 & 3 where black like the previous ones.
1 Day ago: Swapped Fuel Injectors 1 & 2 and 3 & 4 to see if it is the fuel injector by checking my spark plugs in a 2 days.
Gas Tank: no rust
Fuel Pump: Good
Fuel Filter: Good
AirBox Filter: Good
Injectors: Sprayed fine. Didn't run electrical tests though.
Spark Plugs: 2 & 3 Had residue (black) due to running rich. Replaced all of them a week ago. and the 2 in the middle are (black) already.
MAP Sensor: ran the bike with it off. Ran the same except it wouldn't idle correctly with it off.
I'm starting to think that it's electrical. But don't know how to test.
Any ideas? I'm afraid that if I take it to the shop they are going to make me replace everything when it might just be a simple problem. =/
Things I tried:
Gas Tank: no rust
Fuel Pump: Good
Fuel Filter: Good
AirBox Filter: Good
Things I tried:
Gas Tank: no rust
Fuel Pump: Good
Fuel Filter: Good
AirBox Filter: Good
Things I tried:
Gas Tank: no rust
Fuel Pump: Good
Fuel Filter: Good
AirBox Filter: Good
dpg
I already tried changing my coils...... no difference if you are going that route.. Today I changed the injectors, tank and fuel pump. put on about 70 miles. seems to run better but but only better not how it should.
hey liquid did your bike run similar to this before you replaced the hose?
ORIGINAL: hwnf4i
dpg
dpg
i'm guessing that isn't your problem. i still can't figure out why the original cluster wouldn't throw a FI light.
dpg and liquid
I did not want to say this earlier because I am just not sure.. but.. leaking injectors can wassh out cyl walls causinig premature wear of the rings.. the compression in that particular cyl will thus become lower caussing it to run rich further washing out the lubrication that the oil provides making even wworse. eventually the fuel will seep into the oil causing even more damage to the rest of the engine. this is just a "guess" from experience of all the years working on autos.. I may be totally wrong! DPG before doing anything drastic make sure your vstacks are in the correct position. if you have removed and replace your injectors you may need to replace the seals on the injectors also or they "may" leak adding to that gas smell you smell when you stop on top of the poor mileage you may be having since you pulled the injectors.. again a guess.. This has been driving me CrAzY for a while now and if and I mean if I ever fix it I will let you a ll know what it was or what I did to remedy this problem. It must be more common than we know... that is waht is happening to our 2 bikes. Liquid, isn't that a breather hose? I have never followed it other than connecting it back to the box after removing it. dpg if your stacks are in the correct position and you are still fouling those 2 plugs in the center(just a suggestion)I have been running a 1 step hotter plug in hte cyl that has been turning black it seems to be "much better" but still I think i need to go a step hotter. The plugs that I am running are ngk cr9e and the hotter plug is a ngk cr8e these plugs should cost no more than 5 bucks a peice
