frame sliders without cutting a hole in the fairing?
RE: frame sliders without cutting a hole in the fairing?
dont buy the no-cut sliders, yea it sounds like a good idea but in the event of the bike actually falling, these types of sliders are horrible. it is very possible for these to cause more damage than good. just cut the fairing and call it a day, and besides its not as hard to do as some might think
You got to cut it, I ride with a guy that used a frame slider he got on ebay, it used your fairing bolts to hold them on. When he crashed the bolt snapped and so did his fairing. He put them on for show and not function which is the stupidest thing IMO! Might not happen to you but could happen. If you are trying to use them for stunting they dont protect that well try a frame bar or fairing cage, there is 1 made just for the F4I.
Oh I forgot the Honda dealership sells a template that guides you where to cut. It is pretty simple, you can use a dremel or Roto ZIp to cut the fairing then just tap it and then drill. I have never done it but seen it done, didn't look that hard. The guy said it was harder to do an under tail kit if that helps.
