First time valve inspections @ 21k miles
Hey guys, doing some much needed maintenance on my 04 F4i and finished my valve inspecitons. Looks like I need a lot to adjust. Are these numbers normal for a relatively low mileage or am I not using my shim tool correctly? I am sliding them in the correct valves per the manual and I aim for a light resistance when pulling out but I can also go one or two hundreths of mm and still fit with a little more resistance. Let me know if these numbers are right. Thanks.
![Name: io3H2J2.jpg
Size: 851.5 KB](https://cbrforum.com/forum/attachments/f4i-main-forum-11/88748d1683048287-first-time-valve-inspections-21k-miles-io3h2j2.jpg)
Yep that's my plan once I get a shim kit. I noticed that my in and ex markings on the cam gears were not completely aligned with the cylinder head where if the ex is lined up perfectly the in is a tad higher. Is that an issue or as long as they are in the ball park?
So I have the "T" lined up with the index mark and I feel max pressure feeling the pistons for one group are at TDC, I look at the cam gears. The gear with the "EX" is perfectly parallel and lined up with the cylinder head however the gear with the "IN" is not, slightly facing higher than the cylinder head.
