finished frame sliders
#22
RE: finished frame sliders
Just remember you DO NOT want the siders tight against the fairings. You also do not want to use any hard grommets. If you drop it hard the sliders are going to flex and they will end up busting your fairings anyway.
The rubber tub seal ting may be OK, but I have never really worried about it. I used a 2" saw and never looke back. You can see how mine came out here:
#24
If your frame slider is a bit off-centre, here is the rubber gasket you need to make it look better. You just slide it on the puck., no glueing necessary. I pick this up at Home Depot as stated by someone above. The manufacturer & part # are on the packaging. Hope this help.
Dan
[IMG]local://upfiles/5097/78FC9FB388EC4DB09079B28A62995A38.jpg[/IMG]
[IMG]local://upfiles/5097/586C594AF68F49B48602C836098CD51A.jpg[/IMG]
Dan
#27
