Finally...
...Got a pair of A* SMX-4 boots. Been riding with laced boots/sneakers for way too long and love the added protection and the fact that I don't have to worry about laces getting snagged in my clutch pedal.
The fit is great, but I'm still getting used to them, being that I don't quite feel the shifts with the added thickness of the boot.
Have any of you guys adjusted the clutch pedal to allow additional room for a thicker boot? Right now it seems like a somewhat tight squeeze when I first put my toes under the pedal to shift up. Should I bother adjusting the clutch pedal? I figure that I'll feel more comfortable the more miles I put on, but wanted to know what you guys have done. Thanks.
The fit is great, but I'm still getting used to them, being that I don't quite feel the shifts with the added thickness of the boot.Have any of you guys adjusted the clutch pedal to allow additional room for a thicker boot? Right now it seems like a somewhat tight squeeze when I first put my toes under the pedal to shift up. Should I bother adjusting the clutch pedal? I figure that I'll feel more comfortable the more miles I put on, but wanted to know what you guys have done. Thanks.
Great boots but I had to return mine....my bony ankles rubbed the protective disc on one of the boots. I need to get something better than the black Magnum boots I'm wearing....zero ankle protection..steel toe but that is about it.
Goose
Goose
Goose-
I wear the new joe rocket sonic boots.Not as much of a race boot as the smx -4.But fits great and have good protection.
I had to adjust my clutch pedal up slightly to get a good feel.After awhile of riding in boots ,it will feel weird if you ever ride with another shoe again.
Speaking of boots, what would be a good pair that would double as work shoes (not meaning the construction yard, but a business casual office)?
I guess I could change them when I got there but that means more stuff to haul.
ORIGINAL: muckdawg24
I just keep my shoes at work and change them when i get there.
my boots are shot! here are the ones I want to get. There are just so $$$$$$
http://www.newenough.com/boots/racin...cle_boots.html
NIce boots just $$$$..I figure for the daily commute that my sonics are good enough(warm/water proof/but not bad during the heat):
http://www.newenough.com/boots/water...cle_boots.html
You can find them on ebay around 95.00.
cBrentb
Nov 25, 2021 06:05 PM
