FI light Blinking
Old Jul 15, 2008 | 05:14 AM
DarrenF4i's Avatar
Default FI light Blinking
Hi All, I had just bot a 2002 F4i and I discovered that when i start the bike when the engine is cold. The FI light will blinks, it will flash twice in an interval of abt 1.5s. The RPM will be abt 700-800rpm upon the engine fire up. Then it will shoot up to 1.5k rpm in the next 2-3sec. Then the FI light will keeps blinking.
So when the engine is warmed up. I off the engine switch, then on again to fire up the engine (the ignition key is still at ON). The FI light will goes disappear and the bike will idle normally.
Do you guys encounter this problem before and if any bros here know what is the problem ? Please advice.
Thank you !
Old Jul 15, 2008 | 08:59 AM
Hayden06F4i's Avatar
Default RE: FI light Blinking
im not sure what the prob lem is, but i do know the FI light flash es a diff # of times for diff "codes" as to what is wrong, maybe some one can chi me in with wh ere to fin d the c ode l ist.
Old Jul 21, 2008 | 08:05 PM
DarrenF4i's Avatar
I have no idea how to determine how many blinkcount that will be for my case. The FI blinks twice within a interval of about 1.5s. The Engine can start normally when such thing happen. Any kind souls can help to advice me ?
Thank you !
Old Jul 21, 2008 | 08:16 PM
randyjoy's Avatar
2 blinks is loose or poor connection of the MAP sensor vacuum hose or faulty MAP sensor.
MAP = manifold absolute pressure, the sensor islocated towards the front left, in front of the cylinder heads.
Old Jul 22, 2008 | 03:39 PM
spooled/600f4i's Avatar
i had the exact problem all it is you have a poor connection in the MAP curcit in the vacuum line just replace the line and it should be good to go!
Old Jul 22, 2008 | 09:07 PM
DarrenF4i's Avatar
Thks Spooled .. will try it out and will post the result here. Cheers !
Toe-knee
Jun 17, 2011 04:19 PM
Tone
Jun 22, 2010 12:50 AM
rmtcrib
Jul 1, 2009 09:20 PM
Slim7546
Jul 3, 2008 05:25 PM
02F4i1562
May 22, 2006 03:13 AM
