FI code for 02 sensor HEEEEEELPPP!!!!!!!
Old Nov 3, 2008 | 09:50 PM
ShaneF4i's Avatar
Default FI code for 02 sensor HEEEEEELPPP!!!!!!!
ok I have a major dilema here. I have a 2001 CBR F4i that I purchased about a month ago. It has 2 codes that it is showing. Code 2 which is the MAP sensor.
And the second code that is really confusing me is Code 23 which is the 02 sensor code. As far as I can tell my bike is NOT a Cali Model. I do NOT see an 02 sensor on the mid pipe. What should I do?
Old Nov 3, 2008 | 10:28 PM
FLYOU's Avatar
Default RE: FI code for 02 sensor HEEEEEELPPP!!!!!!!
what type of MPG is your bike getting? Does it idle rough? Popping sounds out exhaust? any other weird things?
Old Nov 3, 2008 | 11:15 PM
ShaneF4i's Avatar
I get about 95-110 miles before the Reserve Bars show up on average. Idles clean no bogging. No popping sounds at all. Only bad thing I notice is the FI light on.. Runs great and strong.
Old Nov 3, 2008 | 11:42 PM
FLYOU's Avatar
yeah you're definitely running rich for sure with that type of fuel economey. one thing i've noticed in the past 2 years is that the error code #2 is rarely a problem with the map senor. 90% of the time, the people who are getting this error have a faulty fuel pressure regulator, or one that's about to go. I've heard countless posts of MAP2 codes where the FPR was actually the cause of the problem. Mine is about to go on my bike right now, and I get the #2 code quite often. I still get about 130 miles per tank, but better safe than sorry. The fuel pressure regulator is probably the 2nd biggest complaint with the F4i, as a lot of them crap out after a few years.
So yeah, I'd check the FPR first and make sure she's not starting to go. Even if she isn't, and if she's fine, I'd replace it anyway. It's only a matter of time lol...
Old Nov 3, 2008 | 11:47 PM
ShaneF4i's Avatar
From reading other posts about the FPR going out I would have Gas in my Oil. I do not have this and also I checked the spark plugs and they were also clean.
Why would I get code 23 if I do not have an 02 sensor on my bike?
Old Nov 4, 2008 | 07:38 AM
jonld's Avatar
If your getting that bad of mileage you've either got a bad FPR or open intake valves. I would guess the FPR as with open valves it would be hard to start and would idle till warm. You dont necessarily have to have gas in the oil, it's just normal if you do. Pull the vac line off the fpr and see if there is any gas whatsoever. Also does it have a PC3 or yoshi EMS? Im not sure what distinguishing marks like VIN or anything that distinguishes a cali and a non other than the o2, but there are o2 blockoffs and what not. That tells me that you should check and make sure its not a cali model that has the o2 plug fitted with one of those modules. Also another thought, I would suspect the Cali model to have a different ECM as it acts differently to what it senses from the O2. Maybe your ECM was replaced with a cali model and its looking for a O2 sensor. That would cause the system to always run in a hindered mode. Check your ECM part number and post back.
Old Nov 4, 2008 | 12:58 PM
ShaneF4i's Avatar
I talked to the guy I bought it from today and he said he DID replace ecm. I bet he got a Cali model by mistake. Gonna have to search ebay now for a decent onehopefully not too expensive.
Old Nov 4, 2008 | 01:08 PM
FLYOU's Avatar
cool. hopefully that will fix your god-awful gas millage problem too...
cbrryno
Sep 9, 2011 07:44 PM
redlink15
Jun 13, 2007 12:05 PM
xds949
Feb 18, 2007 09:51 PM
The Twisted Grip
Sep 15, 2006 06:41 PM
The Twisted Grip
Jul 10, 2006 01:49 PM
