Fast Idle Question
Yep, I just wanted to double check cause I'm not really looking forward to taking off the throttle body. Thx again Donny for pointing me in the right direction and the matter. Also from searching here on the forums most people that posted on the subject, there idle was stuck open and idling at 3,000-4,000 rpms. I also wasn't sure if it was just idling low cause it is summer and my garage avg temp this time of year is 75°F+.
Thx again
Moses
Thx again
Moses
My F4i has a BMC filter, bootleg pipe and correctly mapped PC3
I have noticed lately that the COLD idle (not warmed idle..I set that to 1400 and it pegs it perfectly) it idles low at 1000-1100! It never used to do this (it would idle 2000-2200 upon cold start up then creep down)...I chalked it up to the PC3...it seems lately it has gotten worse though
Barley holding 1000rpm upon cold start...never stalled..just seems to have a hard time? I also get the FI light every now and then.
Anyway, I unplugged and cleaned the MAP sensor connections and reset my battery to no avail....
What do you guys think? The bike runs strong as ever and I know the MAP is perfect for the pipe.
I mean Is it the wax unit? Would a wax unit go out after only 13k miles? How much and how hard is it to replace?
I know PC3's can do some wierd things/throw a FI light now and again but I cant figure this one out!
![Icon No](https://cbrforum.com/forum/images/smilies/icon_no.gif)
Thats exactly what mine is doing Noober. It all started after I installed my K&N air filter, Kleen air mod and PCIII w/ custom map. My FI light never comes on though since I installed a O2 sensor eliminator. I also left my PCIII plugged in and put my O2 sensor back into my mid pipe to see if that would help but it did not. The bike still idled the same w/ or w/ out the O2 sensor plugged into the mid pipe.
Maybe I'll hold off a few more days and see if other people are also having this same problem.
Moses
Moses
