Fan not working where to look?
Old 06-22-2010, 05:45 PM
rosscopeeko's Avatar
Default Fan not working where to look?
My 06 F4i has an overheating issue. Now that's it's getting hot out i'm a little worried when i'm riding in the city. My temp will climb and climb until i get moving. Today when i got home i checked to see if the fan is working, it was a no go. I checked the fuse under the seat as per the manual, but it's fine. Where should i look next? Thanks guys.
Old 06-22-2010, 07:51 PM
cbr900racer77's Avatar
Remove plug from thermostatic switch (should be on lefthand side of radiator near the top). Run a jumper wire from that plug to the frame (or other good ground). With key on, fan should run. If it does, you know fan is good and is getting power. Also means problem is with your switch. If fan doesn't run, either fan motor is shot or isn't getting power. Some people hook an over-ride switch up so they can manually turn on fan when temps are getting warm. Just splice into wire going to thermostatic switch and run to a switch. Run other side of switch to a good ground.
snowboarding82
02-28-2010 05:17 PM
Miller
01-17-2010 06:06 PM
DakotaCBR
05-01-2008 05:59 PM
willklee
03-30-2008 05:57 PM
Bklynjoker
05-13-2007 12:00 PM
Quick Reply: Fan not working where to look?
