F4i won't start, not priming, no headlights
Old Jul 4, 2010 | 06:12 PM
vr6ptstyly's Avatar
Default F4i won't start, not priming, no headlights
Well first hello to everyone. I recently bought an F4i, I've been riding it around the past few weeks no problems. Last night went to eat come out to the bike and the fuel pump won't prime, no clicks from the relay, and the headlight is not on when the ignition is on. Relay,igition, bank sensor? everything seems to be checking out.
I did some voltage and continuity checks, but I'm fairly stumped. I also have a manual that I've been doing some troubleshooting with, just wanted to post up get some help. Thanx
Old Jul 4, 2010 | 06:38 PM
motorhorse's Avatar
sounds like a problem with the headlight. did you check the connections? if the headlight isnt connected it will kill power to the starter. if its plugged in it could be a bad wire. check continuity to all the wires leading from the headlight
Old Jul 4, 2010 | 07:06 PM
vr6ptstyly's Avatar
yup it's fixed didnt even have a chance to check for any responses.. haha I went back out and started pulling connectors and it was the big one behind the left fairing. It was the pin in the corner with a white wire, it was a bit corroded. So you were def on the right track..
In the interest of not making a new post tho I've had a weird rattling noise coming from the cover for the "alternator"? Thought it was my cam chain getting a little worse but it's something else. It comes and goes sounds similar to a piece of metal or something getting thrown around. No biggie because I'll have the bike serviced soon, just wondering if someone had similar experience. Thanx
Old Jul 5, 2010 | 07:09 PM
motorhorse's Avatar
if you suspect metal being thrown around in the case, i would def get it serviced asap
dafizuck
Nov 16, 2014 04:33 PM
clj016
Jun 15, 2011 07:47 PM
FLATBLACK740
Jun 11, 2010 09:33 PM
Turboedsupe
Oct 6, 2009 02:45 AM
