F4i wheel measurement?
Would one of you measure your rear wheel between where the sprocket carrier and brake rotor mounts. Just the wheel thickness please, no hub or rotor. I want to put a widder rear wheel on my old F2 without a bunch of machine work. I read the 900 rear wheel swap and its just too much machining for me to get done. I thought if the f4i and f2 wheels were the same thickness then I would just have to just put my sprocket\hub and brake rotor on and my spacers. I want the wider wheel so I can have a choice for better track day tires. I was just wondering if this would work. I know f2 wheel is 4.5 inch and F3 wheel is 5 inch wide but they still dont recomend a 180 tire. F4 and F4i are 5.5 inch arent they? Thanks alot for any help.
