F4i Idle Problems....HELP
Old Aug 5, 2011 | 09:47 PM
ars1986's Avatar
Default F4i Idle Problems....HELP
Ok, this is a long story and i guess i will just start at the top. I blew a spark plug out of the cylinder head for starters. I tear the whole bike apart and get all four cylinders heli-coiled so that i never have to mess with this again.... I have since put the whole bike back together replacing all gaskets, fluids and spark plugs... Now my bike will not start unless i crack the throttle and will not hold idle at all. If i let off the throttle it just dies out and it is not throwing any fi codes. I did a ton of trouble shooting and have check everything a million times, there is only one way i can get the bike to hold and idle and this is with the airbox completely off and the map sensor and iat sensors unplugged. The fi light will throw the code for these two sensors being bad but the bike will hold an idle.. This just blows my mind, and i am completely lost on what to do to get this bike going again. Any help would be greatly appreciated.... Thank you in advance.
Old Aug 5, 2011 | 11:55 PM
backyardmechanic's Avatar
is the idle cable hooked up? mine came loose about a year ago and i really threw me off until i figured it out
Old Aug 6, 2011 | 05:11 PM
ars1986's Avatar
yes the idle cable is hooked up and works as it should...im disappointed that no one on here knows what is going on
Old Apr 7, 2012 | 12:25 PM
ars1986's Avatar
ok i finally got around to working on this thing again. here is whats happening now. i have it all put together and im getting ready to sync the throttle bodies. i start the bike and its idle is around 3grand. im throwing no codes at all, the throttle response is great if i hit it. if i pull the hose off the map sensor the idle will go down, with no codes being thrown. i do not understand whats happening. any help from the community?
Old Apr 11, 2012 | 02:10 PM
RobertF4iSeLfMaDe's Avatar
I sm not sure but mb the timing? and I am looking into this for my 02 f4i and possibly do you know anything about ignition timing?
Old Apr 11, 2012 | 02:54 PM
74demon's Avatar
as far as the high idle goes, is your coolant full?
did you get the problem of it not idling fixed? that was sounding like a vacuum leak to me, or a tps not plugged in or out of adjustment. but now it idles high...
Old Apr 30, 2012 | 10:36 AM
ars1986's Avatar
ok guys finally back to fixing this thing. i have fixed the high idle, i took apart my whole wire harness and cleaned up all the plugs and re checked all the vacuum lines, everything is looking good there. now i am finally working on syncing the throttle bodies. i have a motion pro sync gauge and i calibrate it per manual instructions hook it up and try to adjust the settings so they are all the same.
I know i am supposed to have 2,3&4 all in sync with 1.
this is where i run into another problem. i can get 1&4 in sync together and 2&3 in sync together, but 2&3 are considerably higher than 1&4. there is no way to bring 2&3 down because i have run out of adjustment room on the screws.
i am completely stuck on what to do here.. if i had the cash i would take it somewhere to have it done, but there is not an option.
any ideas guys?
Old May 1, 2012 | 01:17 AM
mnguyen84's Avatar
when you're bike warms up, it should be idling around 1.3k rpm. You may want to recheck your ignition pulse generator, and its wires and connectors.
Old May 1, 2012 | 06:46 AM
ars1986's Avatar
yeah the idle has been fixed. now the problem is in syncing the damn throttle bodies.
Old May 1, 2012 | 01:52 PM
mnguyen84's Avatar
off topic, but how are you testing the vacuum? i'm thinking about buying 4 vacuum/fuel pressure tester gauges and hooking them up.
