f4i idle jumping up (VIDEO)
Old Mar 1, 2012 | 05:15 PM
hockeyryan's Avatar
Default f4i idle jumping up (VIDEO)
another f4i problem for me.... doesn't seem like a big one. My bike was idling about 600-650 rpms. so today i decided to make it 1500. i thought i had it set and i bimped the throttle a bit just to make sure and this problem happened. it started idling at 2k and the started going higher eventually hitting 3k when already warmed up in the 170s. also not sure if its just me but does the idle seem inconsistent..?
help if you can
-Ryan
Also two more things
where do these two hoses plug into? the have a vacuum when i put my finger over them
[IMG][/IMG]
and when the bike is off and i opened the throttle white smoke was coming out of all 4 throttle bodies and smelled of gasoline. (not sure if you can see the smoke in the picture)
Old Mar 1, 2012 | 05:44 PM
74demon's Avatar
check you coolant level. the wax unit brings the idle down as the hot coolant goes through it. if your coolant is low, it will have a high idle. also i maybe hear a vacuum leak. no sure though, hard to tell by the video. look for a leak as well as that can cause a high idle as well.
Old Mar 1, 2012 | 05:59 PM
hockeyryan's Avatar
the two hoses in the first picture have a vacuum effect. i was curious where they go
Old Mar 1, 2012 | 06:01 PM
hockeyryan's Avatar
also i had the tank propped up with the air box off so it was just the throttle bodies that may be what your hearing. thanks again scott
Old Mar 1, 2012 | 06:14 PM
chambers's Avatar
Do you have a manual, page 1-28 should show you where the hoses go.
Old Mar 1, 2012 | 06:16 PM
hockeyryan's Avatar
i do. always forget i have that.
Old Mar 1, 2012 | 06:21 PM
chambers's Avatar
Hopefully that will show you where they go, I'd get them hooked up and the bike back together then try adjusting the idle again.
Old Mar 1, 2012 | 06:23 PM
hockeyryan's Avatar
ok. i just looked and no hose diagram. ill keep looking. tho
Old Mar 1, 2012 | 06:31 PM
chambers's Avatar
It's not really a hose diagram, just a drawing of the bike essentially like yours is w/ the gas tank and air box removed. It shows several hoses and where they go along w/ some wiring. It's in secion 1 page 28.
Old Mar 1, 2012 | 06:42 PM
74demon's Avatar
is there a diagram on the air box?
