f4i handlebars
I have no idea but I ended up moving mine to be more comfortable... There is a little tab that keeps them in place... i just cut that tab and moved them out a little bit...you will need tokeep checking to make sure you can still lock them though...
you have to cut that tab... look at the very front (closest to the windscreen) of the clipon and you will see a tab that keeps them in place... once that is removed, you will be able to move them as far out as you like... just make sure you can still can use your steering lock...
lumberman
Aug 12, 2005 12:42 AM
