F4i front sprocket stuck
Hey guys, I'm in a bit of a pickle. I've spent the last two hours trying to remove the front sprocket and it's just not budging.
All the weight on the bike, using back break. Pulling with both arms and it just won't move.
It is left loosy right? And only meant to be 40lbs??
It's all sorted now. It was the nut, it took an insane amount of force.
I ended up putting some wood in between the wheel and swing arm. Was still lifting the bike so had to also get someone to sit on it.
I think it must have been tightened on with an air gun as was way over 40lbs torque
