f4i compression numbers
Old Nov 15, 2005 | 03:08 PM
mwehrmei's Avatar
Default f4i compression numbers
I'm looking into buying a used f4i engine, and the seller has sent me compression numbers ranging from 235-245psi on each cylinder. The Honda f4i manual lists the compression numbers as 178psi at 350rpm, which I assume is the speed of the starter motor. Are these higher numbers more accurate, or even reasonable? I have seen similar figures posted elsewhere for f4i compression numbers, but I have no idea how they were arrived at. Is there some other method of testing compression? Thanks for your help.
my98gtvr4
Nov 17, 2008 11:12 AM
SandSucker
May 9, 2007 02:28 AM
LlanoSV
Dec 15, 2006 12:53 PM
grwilson6
Sep 12, 2006 11:37 AM
waz57
Jun 3, 2006 06:44 PM
