f4i clock
press and hold both buttons next to the LCD screen.. when the clock starts blinking, press the bottom one to set the hour (adding 1 hour each time), then press the top button to switch to the minutes and use the bottom button to add a minute each time you press it. Then press the top button again and youre done.
You are right DBEAU it can definitely make you go faster, but it can make you go slower too if you try changing it doing 80mph.
-Back to CBR Time. Just hold in the top button for a few seconds and it will change to kmh.
