f4i bogging down
Old Jul 16, 2007 | 03:46 PM
appleseedcast72's Avatar
Default f4i bogging down
hey, i just bought an 02 f4i about a month ago, and just recently it seems like it's got a little less zip. for example, ill be in 6th on the highway, and kick it into 4th to pass someone, and the bike kinda bogs down then slowly picks back up. The same thing happens in 1st from a stop. Any idea on the problem
Old Jul 16, 2007 | 08:17 PM
2002F4!'s Avatar
Default RE: f4i bogging down
Do you have an aftermarket exhaust? mine does it in 1st...becasue of my exahust but from 6th to 4th to pass you should be pretty hi in the revs to not bog...so i dont no there
Old Jul 16, 2007 | 11:30 PM
Daemian's Avatar
mine does it in first some times as well, but i also have an aftermarket exhaust, and im guessing the previous owner did not remap it
Old Jul 17, 2007 | 05:38 PM
nah, it's stock...oh well thanks anyway
Old Jul 17, 2007 | 06:03 PM
Analog's Avatar
Is it just boggy when you goose the throttle? How does it rev in neutral?
I guess the simple stuff would be the best place to start: Air filter in good shape? Fuel filter clogged? How's the idle, smooth? Check for hissing around the engine? Spark plug condition? Spark plug wire resistance ok? Fuel lines aren'tpinched or plugged? Basically, what you're looking for is something that will effect your fuel mixture, your ignition or a vacuum leak. It'll more than likely be subtle,since it only seems to be pronounced when you have a high demand for performance.
Your chain isn't insanely tight is it?
Old Jul 18, 2007 | 12:08 AM
tytyguy's Avatar
check carbs, chain, oil, trannny, etc....
Ickis
Jun 28, 2012 10:10 AM
hooberjabber
May 6, 2012 11:08 PM
Slavo04
Jul 17, 2009 01:10 PM
2bikes
May 11, 2008 01:19 PM
Ski
Jul 20, 2007 06:43 PM
